plastering onto sealed chipboard - can I do it?
17 Aug 2003
Hi all
We have a stud wall that is made from chipboard, which has been painted.
The chipboard has also been PVA'd - and we want to have the wall skimmed.
Because the chipboard has been sealed, can we do this?
Regards
Nick
Problem here is with movement between boards, as they are chipboard. Plaster will stick provided PVA is used but it will crack at the jionts.
even if you use plasterboard tape?
Should I remove the chipboard and install plasterboard instead?
perhaps... What is the thinnest plasterboard available? Can you get 4 or 6mm?
Will taping the joints not remedy this?
9.5mm is the thinnest plasterboard available.
why not remove the chipboard and fix plasterboards instead?
I think I may well remove the chipboard as suggested.
So just to be 100% sure, even if the joints are taped, they will still crack once plastered onto chipboard, but not if on plasterboard?
I know for a fact that the chipboard jionts will crack even when taped up. Talking from expereince ofcoarse.
Okay, then - I will plasterboard directly on top of the chipboard.
Thanks everyone!
