- Joined
- 8 Jul 2011
- Messages
- 56
- Reaction score
- 0
- Country
I have a damp problem in my dining room. I was seeing large patches on the wall appear when there was rain. I was told by a damp specialist to remove the plaster to the brick, repoint the brick, apply a water proofer and replaster the wall. I have done the stripping, and repointing, and used Thompsons Water Seal as the damp proofer. I used this after asking a member of staff in the building supply store what I would need and explained what I was doing and they pointed me to it.
However, I have recently got the same damp specialist back to install a DPC and he has told me that the Thompsons Water Seal is only to be used on the outside walls, and that when it comes to replastering the wall, it will be a nightmare as the plaster will not stick correctly due to the water not taking to the brick. He said that he will supply me with the correct type of water proofer when he arrives to do the DPC.
Will this be a major problem? What will I need to do to the wall in order to remove the Thompsons Water Seal so that the correct water proofer takes to the wall?? Will replastering be tough?
Thanks.
Thanks.
