I'm having to remove some large areas of old lime plaster from interior brick walls. I plan to put on a bonding coat and then a finishing coat. The brickwork is uneven and there's not enough clearance over the whole area to dot and dab even 9.5mm plasterboard. I need a little advice about preparation of the brickwork.
I'm going to remove all traces of the old lime plaster. Once that's done, should I then seal the wall with a PVA wash or will it be OK to plaster directly over the cleaned surface with bonding?
Secondly, can I/should I put the finishing coat on before the bonding is totally dried out (say a day or so) or does it need to be absolutely, totally dried out before the finish coat goes on?
Finally, I've blocked a doorway with a stud wall and plasterboard. Where the board meets the brickwork/bonding coat, should I be using something like scrim tape from the board to the bonding or is it OK just to skim over the join as is?
Many thanks,
Jim
Many thanks,
Jim
