Due to a poor tiling and poor seal behind the kitchen sink unit and a waste pipe fracture the plaster behind the kitchen sink is shot. The unit is on an external brick cavity wall with cavity wall insulation and is under the kitchen window.
~The kitchen installers situated the sink further to the left than the sink in the previous installation and didn't [edit:render]
The plaster was mush under the tiles above the countertop behind the sink When I took the tiles off to investigate what substrate the loose tiles was on and took out the base unit backboard. I discovered the plastering / rendering was damaged right down to the floor. This was made worse by a fractured waste pipe. This was all hidden behind the units.
I removed the window frame apron, have chipped the plaster above the countertop line, renewed the waste pipe and allowed the area to dry out.
I haven't finished chipping out all the plaster, I wanted to make sure I have all the materials at hand first. There's only me in the house and I've got kinda used to not having a kitchen sink, so I can live with long drying times
What is the best render / plaster and additives (if any) to use given that it will be prone to regular moisture in the event of sinktop seal or tile seal failing in future?
Mortar? (if so what mix?)
Dri-coat
Hardwall?
Waterproofing admixture? (brand?)
Dri-coat
Hardwall?
