I have a 1.6 x 2.2 porch, that I want to plaster the inside of.
The walls are a single skin of brick, and I'm not sure what to do to prevent any damp problems occuring.
I could build an internal wall, so as to generate a cavity, but I don't want to loose that much floor area.
Is there a membrane that I could fix to the wall, so that I could then baton and plaster board the inside face?
Would the membrane need to be breathable?
The walls have a DPC that is lapped into the DPC of the main house walls, and the floor has a DPM that is lapped into the DPC, so I'm not worried about any moisture coming up from below. It is anything that will come through the bricks/mortar than I need to block.
Any advice or suggestions gladly received.....
