Hi , i had this advice:
'First, remove the original timber door frame as plaster won’t stick to wood'
thanks
Does this mean the whole inner part as well, I removed the outside skirting and the door batten on the inner frame, then inner frame is very slightly not flush with the existing wall plaster , it is about 3mm in from the existing plaster
Could I get away with just, leave the inner frame and using it as base to fix the batten to in order to stud out the wall?
thanks
