I have had quotes from plasters for the removal of part of a ceiling across a bay and removal of plaster above and below. There is a crack running down from the edge of the window ledge and the plaster is loosened and needs to be removed.
One plaster has said he would use 'Dot and Dab with new plaster board and skim on the walls. replace with new plasterboard and skim ceiling.'
The second plaster has said he would 'Plasterboard and skim ceiling and Float and skim walls.'
The third plaster said he would 'Remove damaged plasterwork and repair and undercoat plaster. Skim with finish plaster.'
Can anyone tell me which option would provide the better finish?
I had wondered about putting plasterboard onto the walls, when there was previously only plaster there and it is old property of approximately 100 years old. Having read others comments on this site it would appear most of you do not like plasterboard on walls as this can cause problems later, i.e. when redecorating.
Look forward to any replies. Many thanks in advance!
