Its time to resite the Oil Tanks at Home
Boiler was serviced today amd have decided to move the 2 Titam tanks to a new Slab at the Side of the house
( Taking into all the Siting Regs )
the New run woould be 25 Metres and my question is should i use
10 MM or 15 MM tube ?
15 mm was mentioned as its less resistance and more flow over a longer distance , was also mentioned that 10mm is available in longer lengths
so no need for any joints in it
So my question is where can i get either size from in Long Lengths
My self and a friend will Lay the slab and run the Pipe in conduit
and the Oil Engineer will commission the tanks and valves / Tiger loop etc
