plastic & compression
18 Aug 2006
Avon
is it ok to use metel compression fittings on plastic pipe with inserts?
also the blue pipe
also i know you shouldnt use joint compound
As an amateur I have never had much success with these (speedfit pipe - not tight enough and they leak, too tight and they leak) so I use a plastic straight connector to a short piece of copper and put the compression fitting on that. Gives me some peace of mind.
Yes. Don't leave out the insert.
also the blue pipe
Also yes. Also don't leave out the insert.
Correct, but you can use PTFE tape.
