Basically upvc windowboard are fitted the same way as wood.If the old windowboard is okay then you can use no-nail glue and bedded the upvc board onto it or take out the old windowboard and slot the new one into the groove of the window frame then maybe a batten on top of your wall with screw/rawlplug and fit windowboard on top with no-nail glue or window board strap tie into the wall.I have seen it done bedded with sand/cement but must put in self-tapper screw (be careful not to damaged the board on the top surface)under the windowboard for it to grip/bond into the sand/cement.
The only problem with upvc windowboards they do scratch very easily.
