Plastic Pipe Runs?
10 Feb 2009
Bristol
I am about to start fitting a toilet and hand basin in a loft conversion.
The pipework enters the loft space in the eaves in the form of hot and cold 15mm plastic pipe capped tails. I need to extend these to the opposite side of the house under the floor of the loft conversion into the loft space on the other side.
Is it acceptable to thread the pipes under the floor between the joists without using pipeclips, or will I have to take the flooring up and clip the pipes in place?
Regards,
Jon
You don't have to clip the pipes Jon, but you do run the risk of them knocking when the water is turned off at the taps.....even plastic pipe does this to some degree.
You can minimise this to some degree by slipping foam insulation over the pipes as you install them though.
John :)
Thanks, I have some insulation kicking around so will use that.
Will probably have a lot of questions over the next few months.
Thanks again.
Jon
it's best to insulate all water pipes (hot and cold) by the way, it keeps the hot water hot and the cold water cold, it's obvious but lots of people don't seem to think about that when they're running pipes :confused:
