Guys. We are giving out kitchen a bit of a facelift. The old white radiator is showing its age so we are going to replace it with a modern looking black upright model which will use a bottom feed/side feed. Our current system uses 10mm plastic pipe with the follow in fittings.
When fitting the radiator I would like to hide the nasty looking plastic pipes in the wall cavity and just come through the wall with some 15mm copper/chrome pipe to this type of valve.
http://www.screwfix.com/p/chrome-angled-radiator-valves-15mm-2-pack/37800
I'm thinking of joining the plastic 10mm to the 15mm chrome pipe using a 90 degree elbow in the cavity where the pipe needs to come out of the wall.
Sound sensible? If not, how could it be done? I cannot come upwards as the floor is concrete.
Cheers.
Ash
Cheers.
Ash
