Is it OK to mix different manufacturer's 15mm plastic pipe and push-fit fittings. I'm mainly concerned with recent B&Q's and JG's pipes & fittings.
Thanks John
It's OK to use any 15mm pipe with any 15mm fitting, but the liners should be correct for the pipe used. The main difference as far as liners are concerned is between PB (polybutylene) and PEX (cross bonded polyethylene) pipe.
