Hi All,
Can someone advise me please if i need to protect plastic pipes when setting them in a concrete floor,the pipes are 32mm waste pipe if i do need to protect them what should i use?
Hi All,
You should use 50mm when entering a concrete floor with basin waste, shower waste pipe etc.
And use long radius elbows where direction changes.
That will reduce the chances of blockages and easier rodded.
Solvent weld is a better option also as it reduces the chances of a joint being de-coupled when pouring commences.
