Can the pipe leading from the pressure release valve on a Alpha CD28C boiler be plastic or must it be copper. Also, is there a law that says what it should be made of.
am pretty sure it is in there, i know by the time i got my unsafe situations book out someone else will have the answer, so am staying sat!! either way it would then not be fitted according to manufactures instructions
