I'm in the process of fitting a kitchen and cant get away from the washing machine waste needing to run behind a free standing 90cm range cooker.
I've been told to use no less than 38mm pipe which ends up being 40mm as that's all that is available.
Is there anything that can be done to protect the pipe from heat? Do I need to? Will this be a problem? Is there a particular type if pipe i should use for the run behind the oven?
Any helpful tips greatly appreciated
Cheers
Cheers
