- Joined
- 30 Dec 2022
- Messages
- 3
- Reaction score
- 0
- Country
I replaced the plate heat exchanger 18 months ago and despite the supplied fibre washers and good cleaning of pipe faces, the top supply (mains pressure) joint has always weeped a little, despite re-tightening. With the heat, it quickly evaporates but now the build up of calcium is making me wonder if it will cause a failure of the heat exchanger, just like the previous one. I don't really want to drain down the system and remove it, I just want to clean and re seal the joint. Can someone suggest the best approach, do I use more than one fibre washer to increase thickness, some other type of washer, a sealant (what sort) should I wire brush the surfaces clean, or use emery paper, or even a file (I think probably not) ?
Even if I am advised to remove the whole heat exchanger to clean all the surfaces, I'd still like to know what washers/ sealant to use.
Thank you for any advice. Andrew.
