is it the pump? does it need unblocking? or replacing? is that easy, how do i drain the water, what are the steps to fixing this problem? how much is a pump likely to be? MANY MANY THANKS
may be the pump, may be blocked filter, no idea what so ever.
How ever do this.
pull m/c out, remove grey pipe from sink or where ever (NOT m/c end) put pipe in a bucket, if water runs out fast its pump, if its slow its filter / pump blocked, no need to turn m/c on
so to confirm...if it flows fast into bucket i need a new pump, if it is slow i need to unblock the pump....it's not the filter because i cleaned it out and it still doesn't work although perhaps the blocked filter caused the blocking/damage to the pump( i'm just guessing..have no idea .. but would like to fix it myself.). ....if it is a new pump how much is it likely to cost(just a rough idea)
pull out machine ant tip backwards 45 degrees against solid object. Then remove filter if clogged up clean and replace. If it is clear there is a possibility of one of the pump wires being "off". I had this loads of times in the past.
You can drain the water from the front osing a shallow tray.
