Please can someone recommend...
7 Oct 2004
I am probably going to go for this, for my shower room:
https://www.toolstation.com/bathrooms/shower-trays/c364?brand=Mira&material=Acrylic+Stone+Resin
Mira 900mm 760mm Acrylic Stone Resin Shower Tray
Could someone recommend a decent shower door and side panel brand.
I wanted something that will last, so happy to pay a reasonable amount but not something that is really expensive. Just a genuine brand but not cheap and nasty or high end.
Also I assume as long as the size is ok different brand trays and enclosures work ok together? You don’t have to have the same make for both tray and door?
Many thanks.
Mira or Kudos. Personally I prefer Kudos
Thanks, just checked and annoyingly they dont have the size tray i need for Kudos.
Can I use a mira tray and ideal standard door and side panel?
Anyone have any experience using Ideal Standard shower tray/enclosure, I assume they decent enough to use?
Thanks again, any ideas/advice appreciated
Never used the IS but there's no reason why you couldn't use a Mira tray and Kudos enclosure, or Mira tray and Mira enclosure
