Hello!
I have just removed some tiles from my batchroom wall and it has left some large holes in the plasterboards in some areas, the largest probably about the size of a breakfast bowl. Can you advise me of the best way to patch up these holes before putting the new tiles down? The main problem I can see is that, as it is a dry-internal wall, there is a large gap between the plasterboard and anything behind it, so there are no blocks or boards immediately behind the wall for several feet and so, I can't just simply put filler into the hole as there is nothing behind it to stick to!
If you have any ideas as to how I get round this problem I would be very grateful!
Many thanks
Jon
Many thanks
Jon
