Please help how do I Fix this
28 Sep 2009
Kent
At the top of one wall / ceiling the plasterboard was bubbling on the tape.
I have cut the bubble out and I was tempted to take the whole tape off.
It now looks a bit of a mess have I done anything wrong?
Should I just fill the bit I have taken out and if so what should I use. Do I
Try and stick the other end back up?
Should I just take the whole tape of and fill all along?
Any help would be great.
Thanks[/b]
fill it and sand it down,then repaint.
what you removed was either a paper strip or scrim,used to join boards together.
Is it important should I take it out all along so it does not bubble in the future.
I am just about to start another room and the same thing has happen last time I just filled it with polycell one fill but it does not look great.
I am going to cut away the bad piece again should I replace the tape or could I just use easi filler.
