Hi all ,Newbie here
need your venerability...can anyone identify the manufacturer of this blessed fire please
I think its about 15 years old
ever so gratefull if anyone can
yes it does say 618W and the link has the thermocouple that I'm after..we have had the fire from new but its not really for heat more for effect.
The fire keeps cutting out after a few minutes lately which is worse when we put the fret on.But if I keep a blowtorch on the TC it stays on.
What dya think
I do appreciate your help on this subject
What dya think
I do appreciate your help on this subject [/quote]
I hope this repsonse is not too late! DO NOT order the t/c, as it is not causing the problem. We won't give actual gas advice here, suffice to say that a service by a Gas Safe RGI MAY get it going properly. If that doesn't sort it, he will order the right parts. Phone a GS RGI and explain the problem BEFORE he visits.
What dya think
Good luck[/quote]
Understood
I wont do anything then, thanks for all your imput
wouldnt want to blow misself and next door up !!!
