Hi, I have a problem with my promax 24he boiler. It keeps locking out. The main pcb has been replaced, had a new burner last year also. When replacing the pcb my plumber put a new combustion door seal in as this had burnt away. For 5 days the boiler was fine, then it started locking out again. Stays on for 30 mins each time. I took the covers off it today and noticed the following.
1. The new door seal has burnt away again on the rhs nearest the pcb, some blackening on the actual door itself.
2. Condensate trap is quite full, both on left hand half of trap and right hand half has a lot of debris in it.
My gut feel is it's locking out due to an overheat as a result of the burnt door seal. My question though, is why is it burning them ?
Also, should the condensate trap be as described above or both chambers empty ?
Please help as I have already spent over £250 on this problem already.
Lee[/code]
Lee[/code]
