Thank you - Can you also quickly answer whether you would also rip out the system? It works and must have cost a bomb to install when put in. Is it really a good idea to replace with plastic two pipe and will it make that much of a difference?The system is probably pumped CH with gravity HW, certainly going by the size of the HW primary.
Ideally you want someone who is experienced with 1 pipe systems to come and have a look to determine how the system is set up. If it is a 1 pipe and you are not in a position to change to a 2 pipe then it needs careful control and balancing.
Unfortunately you can't just drop a new designer column rad onto the system and expect it to work, in fact you can't just drop any new rad onto the system and expect it to work, it needs an experienced bod to fit as it need to be piped in a specific way/position and then the system needs balanced again.
Can you also confirm this is called gravity HW when the flow is pumped up but the return is left to itself to come back to boiler
Thank you so much !
