I have just moved in to a new flat which has an immersion heater as seen in the following images:
View media item 87362 View media item 87363 View media item 87364
I have economy 7 electricity supply, in the picture showing the switches, switch 02 (further back into cupboard) connects to the bottom of the tank via the wire seen in the first picture. Switch 01 goes up to the back then disappears into the wall at the back, so not 100% sure where that goes off to. Having 02 on results in the electric heater starting (can hear it working) regardless of the switch position of the other.
What would be the best practice to use this immersion heater as cheaply as possible, considering we would only use hot water to wash dishes / hands (shower has it's own electric heater)?
Would leaving 01 switch on heat up during the night? (I will experiment with that tonight)
Thank you for your advise and any help you may be able to give me, I am a complete novice in regards to immersion heaters![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
