I feel as though i am in uregent need of some help and advice.
I moved into my huse about 8 weeks back. It is a turn of the century house and the bathroom is downstairs.
It is heated by a 'back boiler' (in the dining room) and the copper tank is located next to the bathroom. Although it is an old house the heating works well and the water heats up mega quick.
Upsatairs in the loft i have one big looking bucket (for the cold water i presume), and smaller bucket for hot water. the pipe run into and out of these.
A few weeks back i heard some loud wooshing, vibrrating noises from the loft but put it down to high winds and rain. However, it has again started today. I chose to investigate as the pipes which run down from the loft and through our bedrrom were making a proper roaring, wooshing and genreally loud noise. It seemed to start, roar for 10 seconds, and then stop. The cycle would continue.
I went up into the loft and as soon as i opened it up, steam started bellowing out. I went into the loft and turned the light on and the whole loft was proper steamed up. The felt on the underside of the roof was covered in water (condenstation).
Over at the 2 buckets i could see that the floorbaord were wet also. Upon watching the 10 second cycle i could see that the pipe that ran into the small hot water bucket was running for the 10 seconds and then stopping. It was spurting the water out as if there was a pressure issue. The pipes were all shaking greatly.
I turned the heatin and hot water off however 2 hours later the problem is stoill going and the noises are still intensive. I know little about plumbing but am concerned about this.
Any Ideas?
cheers,
Aby
Any Ideas?
cheers,
Aby
