Yes the plaster was dry and yes I did do a 50/50 mist coat with Dulux white matt paint first.
The area was skimmed a week ago, it's a doorway that's been plasterboarded up and then skimmed. The main area of the door (the plasterboarded bit) seems ok but the edges where the skim goes over onto the existing painted wall is flaking. I used coarse sandpaper the sand the peeling areas back until smooth and mist coated again and exactly the same has happened. Within a hour it was cracking and peeling.
The wall is a very cold wall (backs on to garage). It's uninsulated as our walls are old solid walls BUT the plasterboarded bit is insulated as has celotex on the reverse of the old doorway and that bits fine.
We had problems during a recent refurbishment of the house with paint peeling. We had professional decorators and it was happening on all the freshly plastered walls that were external and north facing. I'm presuming it's something to do with the cold wall but not sure.
Seeing that mist coating is not working I would really appreciate advice about what to do next. It's now all uneven as the central area is fine and the edges are patchy, peeling and awful.
Really annoyed as I prepared well, did my homework and it looks pants!
