Hi all, really at a loss after months of back and forth on this, would appreciate any direction.
Have a reasonable old glow worm flexicon 24hx condensing boiler.
I’ve had new pipe work run and a pressurised cylinder installed.
Heating thermostat was older than I was so decided to switch to a hive heating and hot water system, my naivety meant I bought the system that my electrician suggested, without realising I had purchased the ‘heating’ Hive, not the CH and HW one, which I have since learned should be the correct one as I don’t have a combi boiler.
Anyway I was assured that this CH hive can still work in tandem with a separate HW control unit which is more old school and manual setting of schedules etc.
However when either the Hw or CH is about to start its schedule, the boiler without fail kicks out in an f22 fault. If I then reset boiler once the Hive or HW control are now on, then the boiler remains on until the schedule is set to turn off, and then the boiler kicks out a fault again.
If the CH or HW is on constant together or either one on its own and I’ve manually turned it on, the boiler works fine.
Does anyone know what could be the issue, is there a signalling issue possibly from the two different controls working against each other?
Or something wrong with the PCB, or maybe that I need to repressurize the system and bleed it all out? My plumber thinks it’s a leccy issue and vice versa! Just panicking as have a baby due in the next few weeks so imperative to have heating and hot water!
Thank you!
Thank you!
