Please help with my Honeywell CM927 dilemma!
28 Nov 2009
Northamptonshire
I replaced my old Honeywell thermostat with a new CM927 today but... it doesnt work... Power light is on - remote thermostat turns unit on at right temperature, but boiler doesnt fire up... I have reinstalled the old thermostat in case I had blown a fuse somewhere but that works perfectly.
Wiring on old unit goes 1 to 5
and wires go into 1 = Permanent live 2= neutral 3= switched live.
There are four wires going into the unit - two live and two neutral
The new unit has six slots N L L A B C
I wired 1 into L, the 2 neutrals into N and the switched live into B....
So why isnt it working?
cause you havent wired it correctly
your new receiver has a permanent live to L
a permanent neutral to N
and your switched live and live return go in A and B
Ok - sussed it !
Had to put a bridging wire from second L connector to A - B is correct as switched live = all works now....
To keep it as simple as possible, A also has to be connected to Permanent Live and then B will become Switched Live.
Edit:You just beat me to it. :)
