Hi, my 15 year old Potterton fires up fine but shuts down after 8 mins so will not adequately heat the rads. With hall stat still calling it will refire after 20 mins and shut down after about 8 mins and so on.
When my engineer visited he said the boiler is locking out because the return temp is too low compared to to flow temp and reckons there is a circulation problem. The over heat stat is not tripping, it is shutting itself down on the boiler control stat.
He has fitted a new pump, flushed the system (but not power flushed) but has not fixed the problem. He is coming back to take off some rads.
Thinking this through, if I shut down the hall stat to shut off the rad circuit as it would be in the summer, and the cylinder water that comes out of the hot tap is hot then with the cylinder stat only calling the return temp to the boiler would only be slightly lower that the flow temp so what he is saying may not be accurate.
In this situation the boiler behaves exactly the same. So I have moderately hot water but hardly any heating.
Thank you very much for any help.
