Please help with Smeg DI409C Dishwasher not completing cycle
11 Jun 2012
Hi can anyone help please, I have the above integrated dishwasher, its been fine until recently, every time i use it on any of the settings apart from the 1st one (soak) it doesn't fully finish.
what is happening is it will get about 3/4 through a cycle then just stop, it will then give 2 beeps and start again (can hear water) then stops and then 1 single beep, then just carrys
on doing that until you turn it off.
When you just open the door while it's doing this there will be exactly 10 beeps, not sure if that's an error code, there certainly doesn't seem to be any light error codes, the same light shows that was on when i set the program and no others.
can anyone please help?
thanks
James
