Hi there
Hope you can help. I'm in the process of renovating my kitchen and I've decided to keep the costs down by preparing all the new electric sockets, fused spurs etc for the Electrician to do the final wiring.
Everything is now stripped back and I need to add some additional sockets and a fused spur for a double oven to an area of the room which doesn't have any existing counter height sockets. When chasing all the cables I know I need to use back plates and oval conduit but I need the following confirmed:
Counter Top Sockets:
A: Can I chase one double socket to another horizontally around a corner?
B: Will it be better to go up to the socket from the floor back down again and round to the second socket on the other wall?
C: If I do the later should I chase the cable into the bottom of the wall running along the floor or leave the wires exposed because kitchen units are going to be fitted there anyway?
Double Oven fused spur and connection:
D: Is it correct that I need a separate circuit for a double oven?
E: Should I have a fuse switch on counter top height and a point to hardwire the oven behind the oven?
Sorry for all the questions and thanks for your time.
[/b]
[/b]
