I had a new boiler installed by a gas fitter, Vaillant 428. He also installed 3 Way valve and a new Cylinder and a new pump and a room thermostat. All honeywell y plan pack.
I'm an electrician and I thought I would wire it up according to the Y plan Wiring Diagram. But the problem is according to Vaillant hand book the Pump should be wired to the Pump terminals in the boiler, but the Y plan connects the pump to the mains going to the boiler.
Does the boiler need a separate fixed feed for mains, or can i use the diagram below to wire it up.
http://www.honeywelluk.com/Documents/All/pdf/940.pdf.
At the moment i have done all the wiring according to the diagram in pdf above, but don't want to switch it on till i'm sure.
Please help.
Please help.
