Hi all,
Here goes, i live on the first floor (flat) of a new build (5 yrs ago) converted granary. My bathroom is ceramic tiled and over the last 2 yrs a number of tiles have started to crack.
I decided to contact the developers to find out what the floor I'm made up from and It turns out i have an acoustic floating floor sitting on top of T&G chipboard which is screwed to the joists. The acoustic layer is bonded together and consists of (starting at the bottom) -
- acoustic foam
-17mm floating plywood on top of chipboard floor
- 17mm Tounge and Groove on top of plywood
- Tiles
At the edges of the room you can feel movement but the middle feels solid.
So before i pay someone to lay my expensive new tiles and possibly UFH, what should be done to stop this happening again?
I'm loosing heart with this as i have called so many companies now and still haven't been told what i should do - only being told why this is no good!
Can i simply screw down this acoustic layer and lay tiles on top, accepting we will possibly loose the sound proofing properties?
All advice welcome and thanks in advance.
- acoustic foam
- Tiles
