Plinth for curtain rail
3 Aug 2005
Surrey Hills
I have a curtain rail where the fixing is coming away from the wall.
I was hoping to fix a couple of small wood plinth to the wall and attach the curtain rail to this.
Does anyone know where I could buy round/square plinthes or similar?
Many thanks.
get some 4x1"[18x95mm] the full length plus 8 inches beyond this will ensure you find brick at least at the ends
No reason why fixing small plinths will be any easier than fitting rail correctly to wall.
When this happened to me i just gouged out the screw hole then bedded the plug in with cement.
Simple fix tbh.
I'm assuming you mean that the screw/plug is loose hence the coming away from the wall?
