Plug and switch height on rewire
24 Oct 2020
Question
I always thought the height of sockets and switches on old houses (1970s) could remain at same height with rewire as not a new property.
Seen rewires recently where sockets have been raised and customers are not happy.
Is this the regulations now?
Its completely upto you, the new heights are only required for new construction and major refurbishment (and this is major-i.e. stripped completely back to sheel with B.C. involved). As the new heights are seen as a de facto standard I'd expect on a rewire that they would be offered as a option, perhaps even the default option, but there is nothing to stop you picking existing heights instead.
I did think that it would not be allowed to to make them 'worse' in compiance with current standards than the existing, i.e. sockets lower, switches higher, but it seems that there is nothing to say this is the case if the job doesn't involve part M (new construction/major refurb/see above) however I would suggest that this might be a silly think to do in absence of some good reason.
Give the new heights consideration, they look daft at first but you get used to them
Building control seem to do what they like, I fitted a wet room for my late mother, and although the regulations say with an opening window you don't need an extractor fan, the LABC inspector insisted one was fitted.
If a room is used for a new function it seems LABC are often involved, living room turned into a kitchen, kitchen turned into utility room, and as an electrician we are often unaware of when the LABC is involved, so unless told we want sockets at x inches above floor level, the safe option is to fit as if a new build.
I can see the reason for placing sockets above the axle height of a wheel chair, their largest wheels normally same as push bike, so 311 mm from floor, below this hight a wheel chair user can easy smash a socket as often they don't see back of their wheels when turning, I noted throughout the ground floor in my mothers house, the damage to walls up to 320 mm, so sockets at 350 mm means in the main out of harms way.
As to making sockets so can be used by wheel chair users, they are sitting down, so as long as not in a corner and above skirting height not a problem, the problem is when mounting items too high not too low. Wheel chair users eye hight around 1200 mm, if the item needs viewing from above, then needs to be under that hight.
I don't think the person writing the regulations has ever used a wheel chair, or been in the home of a wheel chair user, there was no problem upstairs in my mothers house, she simply could not get upstairs, why have an area not accessible with a wheel chair wheel chair friendly? Sockets at the bed head need to be where the bed will not damage them, so not between 250 mm and 600 mm needs to be lower or higher.
Even specialist disabled kitchen installers get it wrong, using a touch control hob which the controls not visible at the angle viewed in a wheel chair, or oven controls with the numbers printed on the top, so a disabled person can't see the temperature set.
If the back boxes chase are ok, it would be silly to move them.
Unless sockets are in the skirting of course.
When I had my first floor rewired, we left sockets and switches in the same position (350mm and 1350mm from floor).
The electrician said it was ok and moving them would've been just a waste of money.
Of course, if you want them at 450mm and 1200mm, go for it.
They do indeed.
I had them round telling me I had to put 100 rigid insulation under the floor. The next guy to rock up told me 175 rockwool would have been OK.
That was my preferred option which Bloke #1 said was not acceptable.
Just a little GRR........
As above, the higher socket heights are specified in Building Regs Part M.
Part M deals with access to and use of visitable buildings.
For new buildings you have to comply with certain socket heights (for wheelchair access, eg). There are also other requirements such as wider downstairs WC doors, ramp access and more.
For existing buildings there are no such rules. In this case Part M says:
You have meet the relavent Building Regulations and the building must not be in a worse condition than when you started!
So, if LABC insist on special socket heights, pull out a handy copy of Part M and ask why he isn’t also insisting on wheelchair access ramps.
