I just tried to wire a socket direct from the consumer unit as it only a foot or so away from the CU. There used to be one connected but I've been decorating and it was old so I removed it. I am sure I am connecting it the same as before and to the same trip switch. I used 2.5mm cable, blue wire to neutral bar in CU, earth wire (with outer) to earth bar and live to a 32 amp trip switch which is protected by an RCD. At socket, blue to neutral, live to live, earth to earth.
When I switch on the socket no problem. When I plug in an extension lead the red light on the extension comes on. But if I plug anything else in light, drill, phone charger, it trips the rcd.
Any clues as to what I've done wrong?
Thanks.
Thanks.
