Plug transformer
14 Sep 2005
Hello,
Could anyone help me find a replacement plug transformer.It is used
to supply a lamp.
Strength Grand
Typ: SG-636A
PRI: 240-50Hz
SEC: 12v-3A 36VA
The wiring from the lamp has a two pin connector attached which
then plugs into the transformer.
Thanks...
Breezer!!
As I live and breathe......Where the %^*(&*()"£% have you been??!!
Maplins dont stock them. Thinking about connecting a new lamp flex and
transformer. Any recommendations of which type to install would be
gratefully recieved.
Craig.
Craig.
as long as the rating of flex,plug and transformer are adequate for the job then that's probnably your best option otherwise if you wish to go down the line of no modification to the lamp then more info on the type of two pin connector is required, what type of connector it is.
