Plugcutters?
1 Jul 2006
London
Can someone recommend a drill/plugcutter set, or would just a plugcutter be enough in itself to use with the right size drill? I'm thinking i'd like to use it to screw some skirting in...
Heh.. sounds good then. I have an sds+ drill on the way though.. so can i get an adaptor for that so it'll take all these hex bits? Then i could get rid of the old drill...
You can get an adaptor, but an SDS is mucho heavy duty for woodworking application like this. If the old drill has a standard chuck then keep hold of it, or replace with a small drill/driver.
Hmn.. i had been wanting to rationalise the toolkit abit.. and thought getting the sds would do this. How do you mean heavy duty, its the hitachi pc3 which is quite a small drill isn't it? Obviously you wouldnt be using hammer for this kind of work.. but do you think it's still inadviseable in some way?
cheers
2 words:
over kill.
It will do the job in the same way that you can use a nuclear weapon to remove tiles in your bathroom. ;)
