Hi Guys,
I have taken an old fireplace and gas fire out and I am having a new fireplace fitted and am hoping to fit an electric fire. The new fireplace has spotlights fitted so I will be needing 2 sockets. My problem is that my chimney breast is very wide so from its edge to the actual fire it is around a meter. The gas pipe(15mm) is already hidden through the chimney breast so I was wandering once it has been disconnected can I run an extension lead through it into the chimney opening(behind the new fire) and connect the fireplace spotlights and new fire (2KW) to the extension lead or will I have to spur off of a socket and fit a double socket in there and can I run both from a spur seeing it is only 2 spotlights.
Thanks in anticipation.
Bas
Bas
