Plum Trees
17 Feb 2008
Berkshire
I have two plum trees that have got very tall. I want to cut them right back. If I cut back to where branches leave the trunk, will new growth start
Yes..If its a well established tree, you could cut every branch off & it would still carry on growing.
Cut it/shape it, as you like
It is a little late in the UK season now to be pruning a plum. It is best done in mid summer for established trees else there is a risk you could allow silver leaf disease spores into the cuts. I would leave it until next year or you risk losing the trees.
Unless it is a huge problem I would try to wait until summer comes around once again. Although it is not essential like dave said you could be risking silver leaf spores, take the risk by all means but if you can avoid it I would wait.
Id also been recomended to use a tree wax wound sealant although a bit of research on t'internet tells me the jury is still out on this method.
I used a wax sealant about 3 years ago on an apple tree, the first year there was a bumper crop of apples. The second year(a poor crop) I pruned the tree as it was out of control and then sealed the wounds. For year three and four the crops were also poor so I would be wary of using wound sealers again.
Not wise. Wounds on trees, (like in humans) need to 'breathe' in order to heal properly.
There's always a risk with sealers that you will seal infection (from the pruning) into the wound. If you prune during the winter months it will have healed over by the time the sap starts to flow.
Poor cropping is nothing to do with wound sealing really. If you prune a tree hard you just encourage growth at the expense of fruiting because it has more root than the size of tree now needs. If you MUST prune then either take it easy or else do some root pruning at the same time.
How does one go about root pruning work? Expose the roots and then?
Ive been growing veg for a few years so Im happy with managing a veggie garden but Im new to tree management.
