Hi peeps I need you advice
Had plastering decorating done three radiators removed.
Found a gas safe plumber well known in the area asked him to fit the three rads back and fix a loss of pressure on the boiler pr valve. He turns up first day I hand him the radiator brackets . He puts on the first rad which doesn't line up with the pipes he can't figure out why . He then said he will need to do a elbow so the rad fits on the pipe work . I disagree as the pipe work should line up hasnt been changed . He drills loads of new screw holes on a new plastered wall and then finally gets the rad on .
Goes to put on the second one and realises the brackets are all different hence why first one didn't line up with the original screw holes .
Leaves after a few hours says need to collect his kids will come back following day . Comes back finished the job. I notice the boiler pressure is dropping look at the rads the new thermostats valves he put on are leaking. Wet patch on my newly painted celling .
He comes back today admits his fault . Fixes the vavle but whilst putting on a new pipe soldering it burns my white skirting to yellow ! He agrees he will send a friend who decorates to re paint the celling and skirting
After he leaves I notice one of the rads is still leaking from the valve very small leak but defo leaking . I have isolated the rad and it's still leaking . I call him he says he can't come back until Monday now is too busy
Is this a **** take or is it just me !!
Shall I ask for some money back . I'm annoyed he is not bothering to come back for a leak . I'm having to put a carrier bag under the valve so my laminate doesn't get damaged
