Plumbing and heating
7 Jul 2006
Hi, well my worcester greenstar condensing Ri system boiler try to fire but it doesn't start, and after so many times it stops and the blue light start flashing, some times ago I noticed when the boiler was working the cooker burner goes low and when the boiler stops the cooker comes up, any idea please.
If the boiler is having an effect on the flame picture of the cooker, then it may be dangerous and must not be used. Get an engineer to check it out, there are a small number of potential issues here that are relatively easily tested by a GSR with the right equipment.
Not disputing any of the above good advice; however we've seen this occur when the gas meter is in the understairs cupboard and the on/off handle (we call it the ECV) has been inadvertently partially turned off. Typically when the ironing board or the hoover is pulled out carelessly.
Might be irrelevant in your case but thought it worth mentioning.
Thanks every one, the problem was the gas meter which wasn't giving enough gas, so it was an Inadequate gas supply.
