Mountains and molehills come to mind, don't know why.
Many difficulties plumbing in a basin? what are they?
I know next to nothing about plumbing in basins, as I've only ever needed to do one. I plonked the pedestal on some squidgy stuff, popped the basin on the pedestal, Marked the two screw holes on the wall, took the basin off, drilled and plugged the holes. Fitted some pipes somewhere near, fitted waste pipe, fitted taps and waste outlet and trap to basin, put basin in place and put screws through holes, tightened screws, connected flexies between pipes and taps, connected waste pipe, turned on water and washed.
But then you knew all this.
