Plumbing in a toilet
1 Oct 2006
Hi, and thanks in advance.
I am adding an en-suite to a garage conversion, and have raised the floor. In the corner of the garage was a toilet, and the new one will go in the same place. However because the floor now is higher the existing waste outlet is at floor level, and all the toilets I have seen have their waste pipes set at 180mm up.
I really don't want to start drilling another hole in my wall to move the waste up, preferring to use the one in place. As I can see it the best option would be to buy a toilet with a vertical outlet, and add a 90 degree elbow to run at floor level, but I can't find any locally, and searching the internet has so far proved fruitless. Does anyone know of a (cheap) supplier?
Cheers
Andy
Andy,
Would you not be able to use a flexi pan connector, this can be bent to the shape you need.
Rico
You are unlikely to find an S-trap (unless you want a little one for a junior school). You can get a thing called "CON-Q" from a good plumbers merchant which will convert a P-Trap to S-Trap
