plumbing in a washer dryer?
mnb
12 Mar 2005
Aberdeenshire
How would i plumb-in the drainage for a washer dryer with only access to the kitchen sink trap and waste? eg a Zanussi or a Bosch? Where would i find a diagram ref. plumbing-in?
i would recomend a stand pipe going outside to drain (same as sink does) dont bother with undersink spiggots or anything else, they get blocked with fluf etc
Thank you Breezer, There's no access to outside walls and no space for a stand-pipe. Would you recommend tee'ing into the waste pipe after the tee in 40mm pipe?
If i go the spigot(s) on the trap will i require one or two spigots?One for the dryer condensate and one for the washer drainage?
