I want to plumb a washing machine into an outhouse and tee off the the cold feed to the combi boiler which is also housed in the same room. Is there a problem with doing this?
No problem per se. You might well find that the mains favours the supply to washing machine if it's on at the same time as you draw DHW, but that's all I can think of.
