I have a mains supplied only domestic plumbing system. There is no water tank in the loft and all taps, etc are supplied directly from the mains.
My boiler is a combi boiler.
The other day I turned off the water at the stopcock and turned off the boiler. I then ran both the upstairs and downstairs taps dry.
My task was to cut a pipe leading to a radiator and cap it off. I cut the pipe and water shot out right up to the roof. Luckily I managed to cap the pipe almost immediately so no harm was done.
I'm confused as to where the pressure in the system came from and, if it's there although the boiler is off, then how can I release it.
There are no draincocks anywhere in the system (it is sealed) and I cannot see any drainage device on/under the boiler.
Is there an easy way to drain a system like this?
Thanks,
TonyT
Thanks,
TonyT
