plumbing up of basin where pedestal does not touch the floor
msh
8 Jul 2008
Ipswich
hi have you got any tips on plumbing up a basin where the pedestal just hangs on the wall currently the pipe work and waste come out of the floor as in the old style, it is on an outside wall can I just bury all the pipe work into the wall or do I have to take it through the wall and back in just below the basin
Any help would be great thanks
These basins are desighed for 'hidden' pipework. You can either box out and run the pipes vertically behind box work or reroute them to run in behind the pedestal. But if its an outside wall you may be able to cut channels into the brick work and run it in that way. The trouble with these things is they look great.....till you get a leak.......
