plumbing
12 Jan 2008
I am changing a plumbing system into an extension , and wish to attach an in line stop cock of some sort to the hot and cold copper pipes running into it ,without having to cut off the water in both pipes.is there any product that will turn the water off and on that i can fix to the pipes, without using the mains stop cock and draining down etc. :
Yes, but not that's worth using!
WHy not just turn the water off while you fit your isolators.
You could freeze the pipes of course.
I was going to say freeze, or even lazier self cutting isolators :LOL:
Yes you could use a live tapping machine, hire one from Pipeline center.
No such thing that I know of
if you find them let me know it would save me HOURS on some jobs
There sure is :rolleyes: Don't know how small they go down to mind.
I know big stuff has the like DIA I have seen them, never had any dealings with them though
But it would take one hell of an engineer to fabricate one for 15, 22 or even 28mm Dia pipe
Have a little look on BES only 15mm though, i've never used them not keen on the self cutting stuff but i have a couple for those special ocasions.
http://www.bes.co.uk/ PN 17035
those are self cutting Taps not self cutting isolators
no good for what tom wants
he seems to want to be able to cut in a stop cock to isolate a feed to his extension, not plumb in a washing machine
either im been really dim :confused: but isn't part no 8769 a self cutting tap
where as part number 17035 is a self cutting isolating valve, thats exactly what the description calls it anyway, and they look like iso's to me ;)
But as you said Tom wants a stopcock not iso's but i was just putting up options. ;)
No its me being dim
you are quite right it is a self cutting isolator rather than a tap, but it would be just as usefull to the OP
Nope cos it is still on a tee
it were an "in line" on an existing piece of pipe I was suggesting.
not a self cutter with a balofix on the end of it, would use one of them for a branch unless it was to a teeny weeny basin because to the tiny apature created by the cutter
